Message 1 of 13
- Mute
- Permalink
- Report
I have a problem with Autocad 2018 with my Mac, anyone can help? (Screenshots attached)
Thank you,
Vasco
Thank you,
Vasco
Hi Vasco,
Do you have this problem from the beginning?
If it appeared suddenly, then: have you tried to relaunch AutoCAD? Restart your Mac? Reset AutoCAD preferences?
Which Mac model do you have?
Maxim
Hi Maxim,
I got all these problems with my new Mac Book Pro (15-inch, 2017)
Mac OS Sierra 10.12.6
3,1 GHz Intel Core i7
16 GB 2133 MHz LPDDR3
Radeon Pro 560 4096 MB
Intel HD Graphics 630 1536 MB
Thank you,
Vasco
By the way,
I've reinstalled Autocad and cancelled Preferences, now I'm using Autocad 2017 but as you know I can't for example use the Flatten command as it is only on 2018 version...
Thank you,
V
One more info,
when I open a new file (acadiso) even if I'm on millimeters (Units) this is what I see (image attached)
Hi Maxim,
I was mentioning units in mm just to explain that whatever I see on the screen (image attached) there is a kind of pixel shadow in the background of the polyline (like if it's in a different scale but it's not).
Tks,
V
Hi Max,
I did verify and is a monitor problem, great! But if I can't upgrade now where do I find linesmoothing? Can't find it in graphconfig.
Tkss,
V
Dear,
I found another trick, enable a two-view viewport and reduce one
I hope it can help as long as Autodesk fixes (I hope very soon) this bug.
Best regards
Delio
