Currently if you change any part of your drawings, small or large and a update is required in a BOM or any other report that is placed on a drawing, you have to:
- Find the exact .set file that was used (Thats if there is one)
- Re enter in any manual edits that was made (regenerating deletes all previous edits)
- Re adjust any formating that was performed (regenerating deletes all previous formating)
Then if you made a mistake you have to go throught the whole process again, which can be quite frustrating and time consuming, especially if you only made a small change.
I suggest that an option be made so that you could right click the report and choose 'Update Report', which will keep all manual edits, formating and update/add the fields that have changed. I would expect that generating reports would only be used to create the initial report or if formating/table layout changes were required.
Colin
