There needs to be an update to the Terminal Properties database.
Most terminals have the same number of connections on each side but with push in Spring/Tension Clamp terminals there is a growing trend to have two connections on one side and one on the other.
For Example...
This is a Weidmuller 794742000 ZDU 6/3 AN BL terminal.
As can be seen in the photo, one side has 1 connection while the other side has 2.
There are many brands and variations on this type of terminal which ACADE needs to keep up with.
The most urgent need at this stage would be to change the Terminal Properties database so that we can set individual connection numbers per side rather than having the one value do both sides.
Regards Brad
