When we use terminal blocks, we number the blocks in order down the strip (obviously) 01, 02, 03, etc.
With multi-level blocks, we add a letter-suffix at the end of the number. A corresponds to the top level, B below that, C is the bottom of a 3-level block, etc. This is common practice as far as I know.
Currently it is a very cumbersome process to accomplish this. I have to number all the blocks Per-Level, so that the tops are all numbered 01, 02, 03, etc. For a 20-block strip, the bottoms will be numbered 21, 22, 23, etc. Now, for every individual block, I have to click the single block, renumber Per-Terminal, add an A suffix, and then it will add the B, C to the lower levels of that block. Repeat for every single block on the strip.
Down the road, as I am dealing with today, if I need to insert a block? FML. Do it all over again, for every individual block.
We absolutely need to be able to number multi-level blocks with a suffix
