Fix existing bugs
Fix existing bugs
Quite simply fix existing bugs in the software that have been there for years.....
I can provide a full list, but I'm sure Autodesk are aware of what needs to be fixed to make the product work as intended.
Please vote on this if you agree.
3 Comments
I agree. They haven't Implemented or even Accepted any of the ideas posted here that are newer than 2015. Did they just decide not to worry about any of their uses ideas or complaints of bugs anymore?
tapani.kuikka
I agree also, there is a lot of functionality impairing bugs existing in the ACADE currently, but no progress seems to be made in fixing them.
A couple examples:
-modeler dll bug.
https://forums.autodesk.com/t5/autocad-electrical-forum/modeler-dll-s-wrong-error/td-p/7357653
-electrical project tree losing track of drawings:
https://forums.autodesk.com/t5/autocad-electrical-forum/autocad-electrical-does-not-update-project-w...
-random crashes and stability issues
-randomly appearing bug that steals focus from other apps:
https://forums.autodesk.com/t5/autocad-forum/autocad-2019-stealing-focus/td-p/8029675
-bug where catalog database view gets emptied if one user is editing it, and another user in that same project makes a change to .wdp file (for example changes drawing settings)
-unhandled exception bugs (might be a error in the drawing, but this kind of error reporting does user no good, there should be more information given on the source of the issue)
ccad2509
not going to happen
still bugs in the software when it was wd tooldox back in in 2004
if they cant be bothered with them what chance have you got with the current batch
