When you insert/edit a child block and select the parent/sibling from any of the lists or the dwg, the Description fields are automatically filled with the description of the block/parent you selected.
If you already have a description filled in, you may not want that description to change. This means either retyiping the description or picking it from the dwg again.
What we need is to have a check box which defaults to automatically updating the descriptions but allows the user to turn of the updating of the descriptions if required.
This would be especially useful for items like multifunction relays which may have several outputs that switch seperatley and are used for different functions.
Regards Brad
