when creating a new catalogue item and inputting the "DESCRIPTION" text... if the text input is longer than the allowed field length (150 characters) in the database, you get a very unhelpful error: "The location of the catalog database is read-only, please ensure that you have write access to the location of the file and try again." --OK is only button to push.
this error doesn't even begin to help you figure out what the REAL problem is in this case.
The "Add Catalog Record" allows you to paste, or type, any number of characters into that box and it won't prevent you from doing that.
It should advise you that you exceeded the allowed field length and let you try again when you push o.k.
