Dear All,
I have a question regarding the wre tagging in AutoCAD.
I want to modify the wire tag.. into this format
Source Destination Format.
SOURCE COMPONENT TAG - SOURCE COMPONENT TERMINAL / DESTINATION COMPONENT TAG - DESTINATION COMPONENT - TERMINAL
Say for example.
I have a push button going to a relay
PB1-4/K1-13
How do I configure that in Autocad electrical?
Thanks a lot!
Joh
Hi Sirs
I still don't know how to use the LISP files.
I've already used the APPLOAD command
but I do not know how do next, the blog has no instructions further after you APPLOAD the .lsp files.
Hope you can help out.
Thanks in advance.
Okay Sir.
Here's what I did.
I have a diagram already with wire no.s as default like on the picture
First, I APPLOAD the minimum_alldwg.lsp file
Then It successfully loaded, then I tried the OTHER_END as per instructed
But it has error
I really hope you could help me on this one Sir.
Sir I also tried both.
I appload - minimum.lsp and OTHER_END.lsp
But still nothing happens...
Thanks.
I really hope you can help me sir on this one..
It does not give me an "unknown command" error anymore but after i APPLOAD both, nothing happens.
What should supposed to happen after I appload?
😞 I really appreciate your responses Sir, I hope you could help me.
Thanks a lot
After the appload, you must type OTHER_END on the command line, to start the command! Just as I've written HERE
Hi Sir,
Please see my new screen cast
OTHER_END COMMAND
https://knowledge.autodesk.com/community/screencast/6fa96876-f4fa-4d9f-9813-473587069e45
I was able to type OTHER_END at the command prompt.
However, it does not give me my desired output.
Say for example from breaker CB2 to transformer T1 tag should be.. CB2-2/T1-H1 and CB2-4/T1-H2 following the format.
Source Tag Name - Source Pin / Destination Tag Name - Destination Pin
I think there's some need to configure the settings or some sort.
We are almost close to the solution of this problem Sir. I am really glad for your responses.
I hope we be able to find solution to this.
Thank you in advance!
Hi Sir I tried using milnumx_alldwg command
Please see my screen cast again on the link below.
Still i wasn't able to get the right ouput I am expecting.
I think what we needed to do is to configure the codes in the lsp files.
However, I really have zero idea on that 😞
I hope you can help me Sir.
Thank you and regards,
Joh
