Wire Tagging
This widget could not be displayed.
Wire Tagging
Dear All,
I have a question regarding the wre tagging in AutoCAD.
I want to modify the wire tag.. into this format
Source Destination Format.
SOURCE COMPONENT TAG - SOURCE COMPONENT TERMINAL / DESTINATION COMPONENT TAG - DESTINATION COMPONENT - TERMINAL
Say for example.
I have a push button going to a relay
PB1-4/K1-13
How do I configure that in Autocad electrical?
Thanks a lot!
Joh
Replies (19)
rhesusminus
There is no out-of-the-box solution for this. But you should be able to achieve this using utility that Nate Holt once created:
http://myacade.blogspot.no/2013/02/autocad-electrical-wire-fromto.html
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
vladop
Hi Sirs
I still don't know how to use the LISP files.
I've already used the APPLOAD command
but I do not know how do next, the blog has no instructions further after you APPLOAD the .lsp files.
Hope you can help out.
Thanks in advance.
rhesusminus
Trond Hasse Lie
Ctrl Alt El
Do I still need to configure something in here?
Okay Sir.
Here's what I did.
I have a diagram already with wire no.s as default like on the picture
First, I APPLOAD the minimum_alldwg.lsp file
Then It successfully loaded, then I tried the OTHER_END as per instructed
But it has error
I really hope you could help me on this one Sir.
rhesusminus
You must download and appload the file OTHER_END.lsp that you can find here:
https://skydrive.live.com/embed?cid=CE5A96771F5F2F9E&resid=CE5A96771F5F2F9E%21309
Trond Hasse Lie
Ctrl Alt El
Sir I also tried both.
I appload - minimum.lsp and OTHER_END.lsp
But still nothing happens...
Thanks.
I really hope you can help me sir on this one..
rhesusminus
Does it still say "unknown command" when you type OTHER_END on the command line, after you have loaded OTHER_END.LSP ?
Trond Hasse Lie
Ctrl Alt El
It does not give me an "unknown command" error anymore but after i APPLOAD both, nothing happens.
What should supposed to happen after I appload?
😞 I really appreciate your responses Sir, I hope you could help me.
Thanks a lot
rhesusminus
It's supposed to change the existing wire numbers. Do you have wire numbers inserted on your wires?
Trond Hasse Lie
Ctrl Alt El
Hi Sir,
Sir I already have wire no.s inserted in my wire.
Joh
rhesusminus
Can you create a screencast showing your procedure?
screencast.autodesk.com
Trond Hasse Lie
Ctrl Alt El
Sir please find link below.
http://autode.sk/2s9hpJK
Thank you in advance,
Joh
Sir Have you seen my screen cast?
Is it viewable?
rhesusminus
After the appload, you must type OTHER_END on the command line, to start the command! Just as I've written HERE
Trond Hasse Lie
Ctrl Alt El
Hi Sir,
Please see my new screen cast
OTHER_END COMMAND
https://knowledge.autodesk.com/community/screencast/6fa96876-f4fa-4d9f-9813-473587069e45
I was able to type OTHER_END at the command prompt.
However, it does not give me my desired output.
Say for example from breaker CB2 to transformer T1 tag should be.. CB2-2/T1-H1 and CB2-4/T1-H2 following the format.
Source Tag Name - Source Pin / Destination Tag Name - Destination Pin
I think there's some need to configure the settings or some sort.
We are almost close to the solution of this problem Sir. I am really glad for your responses.
I hope we be able to find solution to this.
Thank you in advance!
rhesusminus
Ok
I was thinking of the wrong code. Try to type MILNUM_ALLDWG instead, and see what you get.
You might need to tweak the code a little bit to get exactly what you want.
Trond Hasse Lie
Ctrl Alt El
Hi Sir I tried using milnumx_alldwg command
Please see my screen cast again on the link below.
http://autode.sk/2suaLy3
Still i wasn't able to get the right ouput I am expecting.
I think what we needed to do is to configure the codes in the lsp files.
However, I really have zero idea on that 😞
I hope you can help me Sir.
Thank you and regards,
Joh
