AutoCAD Electrical Forum
Wire Number Placement Issue
1 REPLY 1
401 Views, 1 Reply
Having some issues with wire number placement, hoping someone may have experienced this before.
Please see below on the drawing generated with Spreadsheet 2 PLC, but numbered with the Wire Tagging Dialog Box. The wire numbers boxed in red was my anticipated output, but the wire numbers in purple were not:
I also tried to use pick individual wire, while highlighting the leads going into the PLC, that didn't work for me. See my settings below:
Thanks in advance for any advice.
Sam
1 REPLY 1
chris.downing
The problem wires are working as you have configured but they are now centred between the contact and the triangle terminal...
Assuming the wire number does not change after the triangle terminal symbol you can use the Move Wire Number command.
ACADE & PLANT3D Applications Engineer
CAD Training
Standard and bespoke PLANT3D Training and ACAD Training and ACAD ELEC Training
