when i press on the icon menu in the schematic tab and try to insert a Jic schematic symbol the following message in the screen schoot apppears and i can't draw using this symbols
It looks like that file is in the following path:
C:\Users\Public\Documents\Autodesk\Acade 2019\Libs\jic125\1-
you'll have to make sure your search paths include this one.
Best regards,
Jeff
The project isn't active, right-click the project and select activate then try again. The project has file paths that override the application file paths so that should resolve your issue.
You must always 'Active' a project before working on it.
Standard and bespoke PLANT3D Training and ACAD Training and ACAD ELEC Training
