AutoCAD Electrical Forum
template report issue ( from-to)
3 REPLIES 3
muntadhersefaa
352 Views, 3 Replies
dear all
i have critical issue for report format file save , after complete my configuration went to save and finish save the issue start when re-open  format file it will not work need to create new one and resave it , show window ( template are not set for from/to report , so need help with that issue and hope to fixed it
thank you
regards.
Labels (2)
3 REPLIES 3
If you could zip up the set-file, and share it here, it would be most helpful.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
hi
pls check attached file for ( from/to template )
hope to find the issue and solved it
any more information need pls inform me .
thank you
regards.
Can you try to change the name/description of the table from "cable (from/to) list" to just "cable list" ?
Trond Hasse Lie
Ctrl Alt El
