AutoCAD Electrical Forum
template report issue ( from-to)
3 REPLIES 3
muntadhersefaa
263 Views, 3 Replies
dear all
i have critical issue for report format file save , after complete my configuration went to save and finish save the issue start when re-open  format file it will not work need to create new one and resave it , show window ( template are not set for from/to report , so need help with that issue and hope to fixed it
thank you
regards.
Labels (2)
3 REPLIES 3
If you could zip up the set-file, and share it here, it would be most helpful.
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
hi
pls check attached file for ( from/to template )
hope to find the issue and solved it
any more information need pls inform me .
thank you
regards.
Can you try to change the name/description of the table from "cable (from/to) list" to just "cable list" ?
Trond Hasse Lie
Ctrl Alt El
Technology Administrators
AutoCAD Beta
