AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Symbol Builder not starting
5 REPLIES 5
emayerZH9W7
289 Views, 5 Replies
When using either the menu button or typing AESYMBUILDER, I do not get to the Symbol Builder dialog screen. ACADE stays locked until I hit the ESC key.
did a re-boot, tried it with different files, all network connections are good
5 REPLIES 5
jallenDBQ7U
in reply to: emayerZH9W7
Try typing in AEPALETTESHOW on the command line to see if that fixes it.
emayerZH9W7
in reply to: jallenDBQ7U
I started up out of my docking station and it works, I did not use AEPALLETSHOW.
I will see what happens when I get back to the docking station
Never thought this might be a display issue
Thank you for the response
Ed Mayer
jallenDBQ7U
If you sometimes switch the number of displays active that could also cause the issue.  I've had the AE software open a popup on a display that isn't currently active (Windows issue).  Ideally if that occurred it would fix it when you redock.
rhesusminus
The dialog is just off screen. Try these options when AutoCAD "freezes":
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Dialog...
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
emayerZH9W7
in reply to: rhesusminus
That worked Thank You
Technology Administrators
AutoCAD Beta
