When using either the menu button or typing AESYMBUILDER, I do not get to the Symbol Builder dialog screen. ACADE stays locked until I hit the ESC key.
did a re-boot, tried it with different files, all network connections are good
Solved by rhesusminus. Go to Solution.
Try typing in AEPALETTESHOW on the command line to see if that fixes it.
If you sometimes switch the number of displays active that could also cause the issue. I've had the AE software open a popup on a display that isn't currently active (Windows issue). Ideally if that occurred it would fix it when you redock.
The dialog is just off screen. Try these options when AutoCAD "freezes":
