AutoCAD Electrical Forum
Sheet Set Manager will not appear [AutoCAD Electrical]
7 REPLIES 7
Message 1 of 8
james.pillar6ZFJH
369 Views, 7 Replies
Recently my SSM palette undocked itself and ever since I have no way to bring it back or even open up a Sheet Set. I have tried to open up SSM in everyway that I think is possible but nothing seems to have an effect. I do not get an error it just simply runs the command and no palette or file opens.
I have tried opening it via 1) typing SSM into the command line, 2) Navigating to File --> Open Sheet Set --> open .dst, 3) add the SSM icon to a ribbon and click on it, 4) type CUI --> customize workspace --> palettes. I have even tried to create a new Sheet Set and it creates the file but will not allow me to interact with it. My coworkers can open and interact with the .dst so I know it isn't corrupted.
I don't quite know what the issue is or if there is some obscure hidden setting not allowing me to open them but I would love to be enlightened.
The topic title has been edited to improve findability by @alina.balkanskaia.
Labels (2)
7 REPLIES 7
Message 2 of 8
Message 3 of 8
Your dialog box for the SSM is probably not showing because its outside of monitor's screen.
Check this thread out,
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Dialog....
Message 4 of 8
I couldn't get the alt+space > m shortcut to work unless you first manage to click on the palette, even straight after command ssm
messing around on the cui I set the palette like this, apply it, the next time I opened autocad and did ssm it was docked to the left
the windows key + p approach seemed to work, but I haven't actually lost my palette
Message 5 of 8
I still can't seem to make the SSM open up or find it anywhere on the screen.
Message 6 of 8
Do you have one or 2 monitors ?
Message 7 of 8
I have 2 monitors but after not finding it on the first I unplugged my second, redid the prior steps, and still could not find it
Message 8 of 8
In case you are not aware, you have to change your computer "settings" to one monitor, you  can't just unplug the 2nd monitor
