AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
ACAD electrical 2023 treats my components as blocks
4 REPLIES 4
FreddyFW5DP
196 Views, 4 Replies
Hello !
so, Ive been using ACAD electrical 2019 for a while for all of my projects, until a week ago I decided to update to 2023,
everything was ok with installation, but when I start working on my drawings that I already done before with the 2019 version I noticed that the 2023 treats my components as blocks , I'm no longer able to (edit, scoot, change attribute etc) also not able to update wires and wire numbers,
is there some sort of setting that I need to make to make 2023 compatible with older DWG files
thank you in advance !
Freddy
4 REPLIES 4
rhesusminus
in reply to: FreddyFW5DP
There shouldn't be any issue opening older drawings in a newer version.
It's hard to guess what this could be. Will it work as expected with the demo projects that come with AutoCAD Electrical?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
FreddyFW5DP
in reply to: rhesusminus
I tried one of the sample projects that are located in the sample folder and it does the same thing,
I went back to use the 2019 version to complete my drawings,
thank you for your reply,
rhesusminus
Ok. So, a problem with the installation then. You should try to reinstall at some point.
Trond Hasse Lie
Ctrl Alt El
FreddyFW5DP
wow,, yes problem solved after the re-installation , I have control ,now I can see my objects as objects not as blocks
thank you so much for your support,
all the best!
