Numbering wires connected to same bus
This widget could not be displayed.
I'm facing problem in numbering the wires. 3 wires from three phase motor are connected to same bus. When I try to put different numbers on 3 wire originating from motor terminal, only one wire is getting number or all the three wires sharing same number.
vasiqshair
Please post your drawing so we can see what's going on.
jseefdrumr
Also, remember to do a 'Save As...' and change the file type to the 2013 dwg format.
Jim
Jim Seefeldt
Electrical Engineering Technician
Here is my drawing.
vasiqshair
All your motor leads were connected to one phase of the feeder which means all the motor wires were at the same potential. ACADE sees that as one wire. See attached.
Then how he has inserted two different wire numbers for two motor lead connected to same phase?
vasiqshair
You should never wire your motor like that because that is a phase-phase short. That seems to be a screenshot from one of the tutorial videos; the instructor is just giving an example.
