Solved by vasiqshair. Go to Solution.
All your motor leads were connected to one phase of the feeder which means all the motor wires were at the same potential. ACADE sees that as one wire. See attached.
You should never wire your motor like that because that is a phase-phase short. That seems to be a screenshot from one of the tutorial videos; the instructor is just giving an example.
