AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Nameplates
4 REPLIES 4
iewnhoff
306 Views, 4 Replies
Nameplates
I want to put a Nameplate on my panel that does not reference any component in my design.  When I chose the Nameplate icon, it requires me to select an existing symbol.  Any way around this?
4 REPLIES 4
jseefdrumr
in reply to: iewnhoff
Open your footprint icon menu, go to the bottom where it says 'Browse', and then just navigate to the location of that particular nameplate and insert it manually.
**EDIT** whoops, tried that didn't work. But, it should if you just bypass ACADE's normal tools and insert it with Vanilla ACAD commands (INSERT).
Jim Seefeldt
Electrical Engineering Technician
trabuck7
I believe if you would press 'Enter' without clicking on a component, it gets inserted as a standalone item.
Tyler Rabuck
jseefdrumr
in reply to: trabuck7
I can confirm - Tyler's suggestion works.
Jim Seefeldt
iewnhoff
in reply to: jseefdrumr
Yes, it does.  Thanks Tyler.
