Hi, yes. The problem results when I try to modify the library with a .shx font. If I select a .ttf font the routine runs with success.
The script stops and asks me for modifying some text to vertical or horizontal, when I select any of them it stops.
Opening an AutoCAD 2013/LT 2013 format file.
Regenerating model.
AutoCAD menu utilities loaded.
AutoCAD Electrical menu utilities loaded.
Command:
Autodesk DWG. This file is a TrustedDWG last saved by an Autodesk application or Autodesk licensed application.
Command:
Command:
Command:
Command: (COMMAND-S "_.SCRIPT" "C:/Users/JP/AppData/Local/Temp/ace287B.scr")
_.SCRIPT
Enter script file name <C:\users\jp\desktop\a-b\HPB12ML.scr>: C:/Users/JP/AppData/Local/Temp/ace287B.scr nil
Command: _.ZOOM
Specify corner of window, enter a scale factor (nX or nXP), or
[All/Center/Dynamic/Extents/Previous/Scale/Window/Object] <real time>: _EXTENTS
Command: wd_scr_msg "========== Drawing 1 of 2 =========="
Command:
Command: wd_sym_wdlib_doit
_.ZOOM
TAG1 height=1.7500
_.style Enter name of text style or [?] <WD_IEC>: WD_IEC
Existing style. Full font name = AMGDT
Specify font name or font filename (for SHX) <AMGDT>: romans.shx Specify height of text or [Annotative] <4.0000>: Specify width factor <0.9000>:
Specify obliquing angle <0>: Display text backwards? [Yes/No] <No>: Display text upside-down? [Yes/No] <No>: Vertical? [Yes/No] <No>: Vertical? [Yes/No] <No>: wd_scr_qsave3
Yes or No, please.
Vertical? [Yes/No] <No>: *Cancel*
"WD_IEC" is now the current text style.
DESC1 height=1.7500
Existing style.
Specify font name or font filename (for SHX) <romans.shx>: romans.shx Specify height of text or [Annotative] <4.0000>: Specify width factor <0.9000>:
DESC2 height=1.7500
Existing style.
DESC3 height=1.7500
Existing style.
CATDESC height=1.7500
Existing style.
XREF height=1.7500
Existing style.
TERM01 height=1.7500
Existing style.
TERM02 height=1.7500
Existing style.
COMMON height=1.7500
Existing style.
Command:
Command:
Command: WD_SYM_WDLIB_DOIT
_.ZOOM
TAG1 height=1.7500
Existing style.
INST height=1.7500
Existing style.
LOC height=1.7500
Existing style.
DESC1 height=1.7500
Existing style.
DESC2 height=1.7500
Existing style.
DESC3 height=1.7500
Existing style.
Existing style.
XREF height=1.7500
Existing style.
Existing style.
Existing style.
Existing style.
