Hello.
I have this curious problem with graphics in some ACDE windows. It doesn't show me graphics in this windows as well, as in other windows.
I have the ACDE 2015 version.
Please help me, how to fix this.
Thanks and regards
Adam.
Solved by dougmcalexander. Go to Solution.
You might want to check out this post:
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor
Specializing in AutoCAD Electrical Implementation Support
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Hello.
I tested the method you described to me for a long time, but it wouldn't work. I searched the forum for more information about WB_SLB until finally, as a test, I added the {*} character in front of WD_SLB in the WD.ENV file and the icons returned to their place.
Thank you for your help.
