I'm trying to run a line number script in AutoCAD Electrical 2019 that works correctly on my boss' machine that runs an older, non-electrical version of AutoCAD. While the script runs it does not work correctly on AE 19, as every time I run the script I get differing results, sometimes with the numbers out of place and usually with many numbers overlapping. I'm just looking for any bit of insight as it's been hard just trying to research this issue. Are there any known issues or fixes?
Attached is the script, thanks so much regardless.
Hal
Solved by rhesusminus. Go to Solution.
Sorry,
-text j mr 1.6875,20.75 0.125 0 3100 -text j mr 1.6875,20.25 0.125 0 3101 -text j mr 1.6875,19.75 0.125 0 3102 -text j mr 1.6875,19.25 0.125 0 3103 -text j mr 1.6875,18.75 0.125 0 3104 -text j mr 1.6875,18.25 0.125 0 3105 -text j mr 1.6875,17.75 0.125 0 3106 -text j mr 1.6875,17.25 0.125 0 3107 -text j mr 1.6875,16.75 0.125 0 3108 -text j mr 1.6875,16.25 0.125 0 3109 -text j mr 1.6875,15.75 0.125 0 3110 -text j mr 1.6875,15.25 0.125 0 3111 -text j mr 1.6875,14.75 0.125 0 3112 -text j mr 1.6875,14.25 0.125 0 3113 -text j mr 1.6875,13.75 0.125 0 3114 -text j mr 1.6875,13.25 0.125 0 3115 -text j mr 1.6875,12.75 0.125 0 3116 -text j mr 1.6875,12.25 0.125 0 3117 -text j mr 1.6875,11.75 0.125 0 3118 -text j mr 1.6875,11.25 0.125 0 3119 -text j mr 1.6875,10.75 0.125 0 3120 -text j mr 1.6875,10.25 0.125 0 3121 -text j mr 1.6875,9.75 0.125 0 3122 -text j mr 1.6875,9.25 0.125 0 3123 -text j mr 1.6875,8.75 0.125 0 3124 -text j mr 1.6875,8.25 0.125 0 3125 -text j mr 1.6875,7.75 0.125 0 3126 -text j mr 1.6875,7.25 0.125 0 3127 -text j mr 1.6875,6.75 0.125 0 3128 -text j mr 1.6875,6.25 0.125 0 3129 -text j mr 1.6875,5.75 0.125 0 3130 -text j mr 1.6875,5.25 0.125 0 3131 -text j mr 1.6875,4.75 0.125 0 3132 -text j mr 1.6875,4.25 0.125 0 3133 -text j mr 1.6875,3.75 0.125 0 3134 -text j mr 1.6875,3.25 0.125 0 3135 -text j mr 11.375,18.75 0.125 0 3136 -text j mr 11.375,18.25 0.125 0 3137 -text j mr 11.375,17.75 0.125 0 3138 -text j mr 11.375,17.25 0.125 0 3139 -text j mr 11.375,16.75 0.125 0 3140 -text j mr 11.375,16.25 0.125 0 3141 -text j mr 11.375,15.75 0.125 0 3142 -text j mr 11.375,15.25 0.125 0 3143 -text j mr 11.375,14.75 0.125 0 3144 -text j mr 11.375,14.25 0.125 0 3145 -text j mr 11.375,13.75 0.125 0 3146 -text j mr 11.375,13.25 0.125 0 3147 -text j mr 11.375,12.75 0.125 0 3148 -text j mr 11.375,12.25 0.125 0 3149 -text j mr 11.375,11.75 0.125 0 3150 -text j mr 11.375,11.25 0.125 0 3151 -text j mr 11.375,10.75 0.125 0 3152 -text j mr 11.375,10.25 0.125 0 3153 -text j mr 11.375,9.75 0.125 0 3154 -text j mr 11.375,9.25 0.125 0 3155 -text j mr 11.375,8.75 0.125 0 3156 -text j mr 11.375,8.25 0.125 0 3157 -text j mr 11.375,7.75 0.125 0 3158 -text j mr 11.375,7.25 0.125 0 3159 -text j mr 11.375,6.75 0.125 0 3160 -text j mr 11.375,6.25 0.125 0 3161 -text j mr 11.375,5.75 0.125 0 3162 -text j mr 11.375,5.25 0.125 0 3163 -text j mr 11.375,4.75 0.125 0 3164 -text j mr 11.375,4.25 0.125 0 3165 -text j mr 11.375,3.75 0.125 0 3166 -text j mr 11.375,3.25 0.125 0 3167 -text j mr 21.0625,18.75 0.125 0 3168 -text j mr 21.0625,18.25 0.125 0 3169 -text j mr 21.0625,17.75 0.125 0 3170 -text j mr 21.0625,17.25 0.125 0 3171 -text j mr 21.0625,16.75 0.125 0 3172 -text j mr 21.0625,16.25 0.125 0 3173 -text j mr 21.0625,15.75 0.125 0 3174 -text j mr 21.0625,15.25 0.125 0 3175 -text j mr 21.0625,14.75 0.125 0 3176 -text j mr 21.0625,14.25 0.125 0 3177 -text j mr 21.0625,13.75 0.125 0 3178 -text j mr 21.0625,13.25 0.125 0 3179 -text j mr 21.0625,12.75 0.125 0 3180 -text j mr 21.0625,12.25 0.125 0 3181 -text j mr 21.0625,11.75 0.125 0 3182 -text j mr 21.0625,11.25 0.125 0 3183 -text j mr 21.0625,10.75 0.125 0 3184 -text j mr 21.0625,10.25 0.125 0 3185 -text j mr 21.0625,9.75 0.125 0 3186 -text j mr 21.0625,9.25 0.125 0 3187 -text j mr 21.0625,8.75 0.125 0 3188 -text j mr 21.0625,8.25 0.125 0 3189 -text j mr 21.0625,7.75 0.125 0 3190 -text j mr 21.0625,7.25 0.125 0 3191 -text j mr 21.0625,6.75 0.125 0 3192 -text j mr 21.0625,6.25 0.125 0 3193 -text j mr 21.0625,5.75 0.125 0 3194 -text j mr 21.0625,5.25 0.125 0 3195 -text j mr 21.0625,4.75 0.125 0 3196 -text j mr 21.0625,4.25 0.125 0 3197 -text j mr 21.0625,3.75 0.125 0 3198 -text j mr 21.0625,3.25 0.125 0 3199
Above is the code, and here is the example drawing with the script results.
Hal
