AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
In the title block, how do i display the next filename?
7 REPLIES 7
Message 1 of 8
Greatrock85
537 Views, 7 Replies
in a project with multiple files is there a way in the title block to display the next file name (001 -> 005 -> 008 -> etc) instead of the progressive sheet number (1 -> 2 -> 3...)?
Thankyou
7 REPLIES 7
Message 2 of 8
rhesusminus
in reply to: Greatrock85
You must code some lisp to achieve this.
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 3 of 8
Greatrock85
in reply to: rhesusminus
HELP 😭 i don't have the lisp and i don't know how to do it
Message 4 of 8
rhesusminus
@vladop
Do you have anything to help?
Maybe you can teach them Lisp 😄
Trond Hasse Lie
Ctrl Alt El
Message 5 of 8
vladop
Sorry,
I'm busy these days, I barely read the forum.
I found this, I think that's it, though I didn't check.
It should be changed to display the file name, but I didn't really understand what the request was.
Terminal AutoCAD: AutoCAD Electrical's Title Block Update - Previous / Next Sheet Numbers (myacade.b...
The corresponding functions can be found in the API help in section G - Project Management.
Someone help, I don't have time right now.
Vladimir
Message 6 of 8
james_moore
Choose the "filename" attribute when setting up your title block/border block, instead of the "sheet" attribute, if I understand what you're asking.  We use both in our title block.
Now if you want to display the "next" file in a series, not the current file, it would take some custom programming.
Message 7 of 8
Greatrock85
I have this tree Immagine 2023-06-03 225531.png and i want to visualize the next filename .dwg in the title block, "filename" attribute it's ok but it would be some sort of "next filename" attribute
Message 8 of 8
If you don’t want to do any custom programming, maybe enter the FILENAME as the sheet number, without the file extension.
Also assign the Previous Sheet and/or Next Sheet values in Title Block Setup>Drawing Values to write to attributes that you place in your drawing for such values to be shown. I use attributes named PREVSHT and NEXTSHT. I will attach an example.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
Technology Administrators
AutoCAD Beta
