AutoCAD Electrical Forum
In the title block, how do i display the next filename?
7 REPLIES 7
Message 1 of 8
Greatrock85
627 Views, 7 Replies
in a project with multiple files is there a way in the title block to display the next file name (001 -> 005 -> 008 -> etc) instead of the progressive sheet number (1 -> 2 -> 3...)?
Thankyou
7 REPLIES 7
Message 2 of 8
rhesusminus
in reply to: Greatrock85
You must code some lisp to achieve this.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 3 of 8
Greatrock85
in reply to: rhesusminus
HELP 😭 i don't have the lisp and i don't know how to do it
Message 4 of 8
rhesusminus
@vladop
Do you have anything to help?
Maybe you can teach them Lisp 😄
Trond Hasse Lie
Ctrl Alt El
Message 5 of 8
vladop
Sorry,
I'm busy these days, I barely read the forum.
I found this, I think that's it, though I didn't check.
It should be changed to display the file name, but I didn't really understand what the request was.
Terminal AutoCAD: AutoCAD Electrical's Title Block Update - Previous / Next Sheet Numbers (myacade.b...
The corresponding functions can be found in the API help in section G - Project Management.
Someone help, I don't have time right now.
Vladimir
Message 6 of 8
james_moore
Choose the "filename" attribute when setting up your title block/border block, instead of the "sheet" attribute, if I understand what you're asking.  We use both in our title block.
Now if you want to display the "next" file in a series, not the current file, it would take some custom programming.
Message 7 of 8
Greatrock85
I have this tree Immagine 2023-06-03 225531.png and i want to visualize the next filename .dwg in the title block, "filename" attribute it's ok but it would be some sort of "next filename" attribute
Message 8 of 8
If you don’t want to do any custom programming, maybe enter the FILENAME as the sheet number, without the file extension.
Also assign the Previous Sheet and/or Next Sheet values in Title Block Setup>Drawing Values to write to attributes that you place in your drawing for such values to be shown. I use attributes named PREVSHT and NEXTSHT. I will attach an example.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor
Specializing in AutoCAD Electrical Implementation Support
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
