AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
In a license loop that I can't get out of....
7 REPLIES 7
Message 1 of 8
mihenderson6YSDE
520 Views, 7 Replies
I installed from the link Autodesk Access sent me to.  I log in with my company's credentials, but it still asks me to buy or try with the already have a license link in the bottom right.  when I click on the already have a license link, it sends me to the switch user, network license, serial number page.  I'm already logged in, I don't want to switch user I just want to start....
7 REPLIES 7
Message 2 of 8
It says that there's no license assigned to your e-mail address. Are you absolutely sure that one is assigned to you?
Check this at http://manage.autodesk.com
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 3 of 8
I'm not sure of anything.
I can install any other Autodesk software including,  ACADe 2023.  I get stuck in the same loop with ACADe 2023, but after the second time I log in using my company credentials, I can select network license and it will start the program long enough to realize I'm signed in, but on the 2024 when I follow that work flow it actually asks me for a network license.
Edit: forgot to mention that the link seems to take me to the place where I download the software.  What am I looking for?
Message 4 of 8
Are you the contract manager, or the software coordinator?
The one in your company with this role(s), should assign a seat to your e-mail address.
Trond Hasse Lie
Ctrl Alt El
Message 5 of 8
I'm neither of those, just an engineer/user.
We just login with our company credentials and install what we need.  I have revit, Civil 3D, Autocad MEP 2023, Autocad Electric 2023 and some other AD programs installed.  It seems to be a 2024 version thing.  Happening with Autocad MEP 2024 too.
Message 6 of 8
And 2023 works fine?
Trond Hasse Lie
Ctrl Alt El
Message 7 of 8
Yup, all the 2023 packages work fine.  civi 3d, mechanical, electrical, none of the 2024 work though because of the licensing issue.
Message 8 of 8
Try to reset the license first.
Download the tool for this form here:
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/6IFPpIksTDfsCzp1JwIH5k.html
Run the UI version, select AutoCAD Electrical 2024 and reset the licensing.
Trond Hasse Lie
Ctrl Alt El
