In a license loop that I can't get out of....
mihenderson6YSDE
mihenderson6YSDE
I installed from the link Autodesk Access sent me to.  I log in with my company's credentials, but it still asks me to buy or try with the already have a license link in the bottom right.  when I click on the already have a license link, it sends me to the switch user, network license, serial number page.  I'm already logged in, I don't want to switch user I just want to start....
Replies (7)
rhesusminus
It says that there's no license assigned to your e-mail address. Are you absolutely sure that one is assigned to you?
Check this at http://manage.autodesk.com
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
mihenderson6YSDE
I'm not sure of anything.
I can install any other Autodesk software including,  ACADe 2023.  I get stuck in the same loop with ACADe 2023, but after the second time I log in using my company credentials, I can select network license and it will start the program long enough to realize I'm signed in, but on the 2024 when I follow that work flow it actually asks me for a network license.
Edit: forgot to mention that the link seems to take me to the place where I download the software.  What am I looking for?
rhesusminus
Are you the contract manager, or the software coordinator?
The one in your company with this role(s), should assign a seat to your e-mail address.
Trond Hasse Lie
Ctrl Alt El
mihenderson6YSDE
I'm neither of those, just an engineer/user.
We just login with our company credentials and install what we need.  I have revit, Civil 3D, Autocad MEP 2023, Autocad Electric 2023 and some other AD programs installed.  It seems to be a 2024 version thing.  Happening with Autocad MEP 2024 too.
rhesusminus
And 2023 works fine?
Trond Hasse Lie
Ctrl Alt El
mihenderson6YSDE
Yup, all the 2023 packages work fine.  civi 3d, mechanical, electrical, none of the 2024 work though because of the licensing issue.
rhesusminus
Try to reset the license first.
Download the tool for this form here:
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/6IFPpIksTDfsCzp1JwIH5k.html
Run the UI version, select AutoCAD Electrical 2024 and reset the licensing.
Trond Hasse Lie
Ctrl Alt El
