help with a lisp macro
jseefdrumr
Mentor Mentor
jseefdrumr
So I use old-school LISP for my command macros. Currently I'm trying to call the 'create new drawing' dialog. I can enter AENEWDRAWING directly on the command line and get it. But if I try to macro it to something else it won't work. Below is an example of the code I used, along with the simple variations I tried. NOTE: Command macros are literally the only thing I do in LISP, sorry if this is an easy one.
a line of good, working code:
(defun C:EN ( ) (c:AEPNEUMATIC))
what I think *should* work:
(defun C:ENEW ( ) (c:AENEWDRAWING))
other stuff I tried:
(defun C:ENEW ( ) (c:_AENEWDRAWING))
(defun C:ENEW ( ) (c:ACENEWDRAWING))
(defun C:ENEW ( ) (c:_ACENEWDRAWING))
(defun C:ENEW ( ) (command "_AENEWDRAWING"))
(defun C:ENEW ( ) (command "_ACENEWDRAWING"))
These all return either 'no function definition' or 'unknown command AENEWDRAWING', depending on how I tried to call the command. The last one on the list returns 'nil', which is confusing.
Thanks in advance
Jim
Jim Seefeldt
Electrical Engineering Technician
rhesusminus
It's a little bit dirty, but it works:
(defun C:ENEW () (vla-SendCommand (vla-get-activedocument (vlax-get-acad-object)) (strcat "ACENEWDRAWING" " ")))
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
jseefdrumr
Works perfectly, many thanks Trond!
\m/
Jim
Jim Seefeldt
