AutoCAD Electrical 2019 Catalog Edit issue
jopatsuwan
jopatsuwan
Hi all,
Autocad Electrical Catalog edit mode is not working properly,
after i add the new part number into the catalog,  then click Catalog check, Description is missing.
please refer to Video attached.
anyone have the same problem
i try to open the Default catalog with Microsoft Access to see the new part number i put it, but couldn't find it.
not sure how/where autocad Electrical is adding the new item.
Thank you
jopatsuwan
Hi all,
i solve the problem,
Autocad Electical 2019 was edit/lookup in 2018 catalog but check part number in 2019 Catalog.
solution.
option, Support file search path
1. remove all path to old autocad,
2. added C:\Users\YOURNAME\Documents\Acade 2019\AeData\en-US\Catalogs
I believe this problem start from importing the profile from previous autocad to new autocad.
Thank you
