Hello All,
To update tittle block I am use ACADE API
"c:wd_tb_process_one"
I am run this API on every drawing in project and it works for some drawings. but, in some drawing it added "\W0.8000; " text before project title as well as before drawing title. my complete command is
(c:wd_tb_process_one 0 (list (list 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0) 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19))
see output after running API.
Hello rhesusminus,
Thank you for your response.
This attribute is Not multiline attribute and while using "Title Block Update utility" the same problem occur.
Also ,I observe one thing here the attribute name is as expected in attribute edit window but on drawing it's add "\W0.8000;" this text extra(see. attached image).
