AutoCAD Electrical Forum
Error Occure while updating title block in ACADE using "c:wd_tb_process_one"
3 REPLIES 3
644 Views, 3 Replies
Hello All,
To update tittle block I am  use ACADE API
I am run this API on every drawing in project and it works for some drawings. but, in some drawing it added "\W0.8000; " text before project title as well as before drawing title. my complete command is
(c:wd_tb_process_one 0 (list (list 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0) 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19))
see output after running API.
3 REPLIES 3
rhesusminus
Is the attribute in the title block a multi-line attribute?
Do you get this problem if you use the Title Block Update utility?
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
in reply to: rhesusminus
Hello rhesusminus,
Thank you for your response.
This attribute is Not multiline attribute  and while using "Title Block Update utility" the same problem occur.
Also ,I observe one thing here the attribute name is as expected in attribute edit window but on drawing it's add "\W0.8000;" this text extra(see. attached image).
rhesusminus
The /W0.8000 is a control code for mtext/multiline attributes, saying that the width factor of the following text should be 0.8 .
My suggestions are:
1. Do not use a multi-line attribute, as AutoCAD Electrical don't support them very well
2. Go to the text styles (type STYLE on the command line), and set the width factor to 1 for the text styles used for that Attribute
3. Change the font for the above text style
Trond Hasse Lie
Ctrl Alt El
Technology Administrators
AutoCAD Beta
