AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Stop Zoom Extents when importing drawing settings
7 REPLIES 7
Message 1 of 8
bra2692
524 Views, 7 Replies
Various multi-drawing operations (importing drawing settings from XLS, running project wide utility, etc) seem to cause an extents zoom to happen and I'd like this to not happen. Below is some console outputs of what is showing up:
Command:
Drawing Update from spreadsheet
 Checking files for any marked in-use/read-only . . .
Command:
[ AutoCAD - Mon Feb 24 21:12:10 2020  ]----------------------------------------
Loading Modeler DLLs.
Opening an AutoCAD 2013 format file.
Substituting [ROMANS__.TTF] for [C:\r13\com\fonts\romans.shx].
Substituting [SANSS___.TTF] for [C:\r13\com\fonts\sas_____.pfb].
Substituting [isocp___.ttf] for [isocp.shx].
AutoCAD menu utilities loaded.
AutoCAD Electrical menu utilities loaded.
Command:
Autodesk DWG.  This file is a TrustedDWG last saved by an Autodesk application or Autodesk licensed application.
Command:
Command:
Command:
Command: (COMMAND "_.SCRIPT" "C:/Users/[REDACTED]/AppData/Local/Temp/ace44.scr")
_.SCRIPT
Enter script file name <C:\USERS\[REDACTED]\DESKTOP\[REDACTED]\BACKPLATE.scr>: C:/Users/[REDACTED]/AppData/Local/Temp/ace44.scr
Command: nil
Command: _.ZOOM
Specify corner of window, enter a scale factor (nX or nXP), or
[All/Center/Dynamic/Extents/Previous/Scale/Window/Object] <real time>: _EXTENTS
Command: wd_scr_msg "========== Drawing 1 of 2 =========="
Command:
Command: wd_cfg_lst_upd_dwg
nil
Command:
Command: wd_scr_qsave3
_.QSAVE
Command:
Command:
Opening up one of the called script files (ace44.scr) shows this
_.ZOOM _EXTENTS
wd_cfg_lst_upd_dwg
wd_scr_qsave3
These scripts seem to be auto-generated by AutoCAD Electrical as part of the multi-drawing update and there is one for each drawing that is processed. How do I get the "_.ZOOM _EXTENTS" line to not be a part of them?
7 REPLIES 7
Message 2 of 8
rhesusminus
in reply to: bra2692
This is hardcoded into AcadE and cannot be changed unfortunately.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 3 of 8
In the WD.ENV file add * infront of WD (see attached). This normally disables the Zoom extent during file opening. Restart ACADE to reload the WD.ENV
Message 4 of 8
rhesusminus
This does not apply for this...
Notice it says "_E" in the WD.ENV and "_EXTENTS" in the script.
The zooming is also disabled by default.
Trond Hasse Lie
Ctrl Alt El
Message 5 of 8
in reply to: rhesusminus
Yes, it will disable the zoom command because Extent is part of Zoom command and _E is short form of Extents. And it works when you add *. If you check his screenshot, ACADE loads zoom command and applies _extents, see attached.
Message 6 of 8
When I want to apply Zoom Extents manually, in practice, I just type Zoom and type E (or EXTENTS) and hit enter. This will do Zoom extents.
Message 7 of 8
rhesusminus
Did you try this with export/import drawing settings to/from spreadsheet? I did.
As I said, this setting does NOT apply in this case.
I know that you can type E or EXTENTS on the command line. What you see in the OP is what's in the script. And the script says _EXTENTS. If it was the WD_OPEN_DWG setting that applied, it would say _E on the command line, not _EXTENTS.
Trond Hasse Lie
Ctrl Alt El
Message 8 of 8
bra2692
That is correct. I disabled the WD_OPEN_DWG (it was enabled on our setup) hoping it would fix the scripts as well but sadly it does not. That's very unfortunate being hardcoded that way.
