AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Cooridinates conversion
7 REPLIES 7
Message 1 of 8
601 Views, 7 Replies
I have some old 2D drawings that are in the Z - X Coordinates.  I would like to convert the z coordinates over to y coordinates so I can work in the Y-X coordinates.
7 REPLIES 7
Message 2 of 8
rhesusminus
Are you sure that the drawings are in that coordinate system? If you reset the USC to WCS, by typing this on the command line:
UCS
World
Plan
Current
Does that fix the problem?
If not, you'll have to use the ROTATE3D command, to rotate everything to the correct orientation.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 3 of 8
in reply to: rhesusminus
I am not sure that I am asking the correct question.
Here is what it looks like using the Y-X Coordinates
[cid:image001.png@01D27C71.AAE10CF0]
I change the following
[cid:image002.png@01D27C71.AAE10CF0]
To look like this
[cid:image003.png@01D27C71.EEE528F0]
I can work in my drawings but they are in the Z-X coordinates
[cid:image004.png@01D27C71.EEE528F0]
I would like to work in the Y-X. Would like to convert everything in Z to Y.
Did I ask the correct question in the first place? Can this be done?
Jerry
Message 4 of 8
rhesusminus
The images didn't come through.
Are you able to share an example file here, and I'll take a look?
Trond Hasse Lie
Ctrl Alt El
Message 5 of 8
Here you go!
Let me know if there is anything else you need.
Jerry Owens
Electrical Engineer
Waupaca Foundry, Inc
A Hitachi Metals group company
18986 Route 287
Tioga, PA 16946
570.827.3245 ext. 412
jerry.owens@hmacusa.com | www.waupaca.com
Message 6 of 8
rhesusminus
No attachment here.. You have to do it in a web browser. attachments from an e-mail seldom gets through...
Trond Hasse Lie
Ctrl Alt El
Message 7 of 8
Here is a sample drawing.  You will see that everything is drawn using the Z-X Coordinates.
Message 8 of 8
rhesusminus
Here's a short screencast showing how to ROTATE3D the schamatic back to the XY-plane.
The steps are:
  1. Move the lower left corner of the frame to 0,0,0
  2. Roatete everything around 0,0,0
Trond Hasse Lie
Ctrl Alt El
