I have some old 2D drawings that are in the Z - X Coordinates. I would like to convert the z coordinates over to y coordinates so I can work in the Y-X coordinates.
Solved by rhesusminus. Go to Solution.
Here is a sample drawing. You will see that everything is drawn using the Z-X Coordinates.
Here's a short screencast showing how to ROTATE3D the schamatic back to the XY-plane.
The steps are:
