I have a single line diagram where the components are arranged from top to bottom on my drawing. I tried to do a component retag and ACADE updated but from left to right, so my top CB was labelled Q15 but should be Q1. I tried changing the 'Tag/Wire Number/Wire Sequence Order' drop down on the 'Drawing Format' tab of Drawing properties to 'Top to Bottom. moving right' but that did not change anything. Am I missing something here?
Thanks in advance.
Colin
Solved by ramesh.kambang. Go to Solution.
Have you tried sort order option "Left to right, moving down (default for vertical ladders)". Are you using X-Y grid Reference Numbers for format referencing?
