AutoCAD Electrical Forum
Component retag top to bottom
2 REPLIES 2
Cole64
556 Views, 2 Replies
I have a single line diagram where the components are arranged from top to bottom on my drawing. I tried to do a component retag and ACADE updated but from left to right, so my top CB was labelled Q15 but should be Q1. I tried changing the 'Tag/Wire Number/Wire Sequence Order' drop down on the 'Drawing Format' tab of Drawing properties to 'Top to Bottom. moving right' but that did not change anything. Am I missing something here?
Thanks in advance.
Colin
Labels (1)
2 REPLIES 2
ramesh.kambang
in reply to: Cole64
Have you tried sort order option "Left to right, moving down (default for vertical ladders)". Are you using X-Y grid Reference Numbers for format referencing?
Ramesh Kambang
Aerospace System/Design Engineer and eVTOL/EWIS Expert
EASA 21J, UK 21J, MAA DAOS, Certification Specification CS23-29, CS-ANCS, CS-STAN and EVTOL
Please select "Accept Solution" if this post answers your question.
Cole64
in reply to: ramesh.kambang
Yes, that works. Makes sense when I actually read it properly 🙂
