Bus Bar Wiring Numbers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
We use a solid bus bar to connect the incoming of our circuit breakers - I've included a picture of the type of thing....
When it comes to putting this in our circuit diagrams, I have a wire layer called bus bar. What I was hoping I was going to be able to do was to wire in one side of the breaker in cable, use the bus bar across the breakers and out the other side with cable (to reflect the way you might physically wire it). The attached shows the general arrangement with blue being the wires and purple is the busbar. The blue wire layer is the default wire numbering (%N%S).
The problem is when it comes to numbering. All the cables are picking up on the same numbering scheme even though the busbar layer has a separate numbering scheme. Logically ACE is doing what it should by having the same numbering across wires which are connected together but illogically is it changing part of the circuit to a different wire layer and ignoring that particular numbering scheme.
So, my question is, is this the way it's supposed to work? More importantly what can I do to ensure I can have the two numbering schemes when joined in this way? What do other people do in this situation?
