adding more din rail to wddinrl.xls file
EliseMoss
EliseMoss
I added a din rail option to the xls file, but it doesn't appear in the drop down list when I start the wd_dinrl command.
I closed AE and relaunched it and the list is still unchanged. I saved a back-up, but it doesn't seem to make any difference.
I added the AB 1492-DR5 item in the xls file (see attached).
Also, it is unclear in the spreadsheet what units are being used - mm or inches?
Any idea what I did wrong?
TIA,
Elise
rhesusminus
It's all inches.
What XLS-file are you editing?
See the command line to see what XLS file AcadE is using:
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
EliseMoss
Thank you so much! That was exactly the answer! I needed to update the spreadsheet in my Catalogs folder.
