AutoCAD Electrical Forum
BOM Report Quantity off
4 REPLIES 4
440 Views, 4 Replies
AutoCAD 2016
Why would a count be off so far in a report? There should only be one, not 3416.
4 REPLIES 4
TRLitsey
Hi, I would try two things right off the bat.
1, use the surfer dude to find all instances of the block in you project.  If that physical count is what are expecting something else is going on.
2, take a look at the Catalog Record (see attached) and make sure there is not a goofy value in the Count box in upper right corner.
Tim
Good luck, please mark this if it is a solution.
Please mark as a solution if this works for you, kudos are always welcome
Icemanau
in reply to: TRLitsey
Don't forget to check the count box in the Edit Component dialog box in the dwg as well.
Regards Brad
Brad Coleman, Electrical Draftsman
How did you get to the catalog record window that you have there shown there in the image?
Thank you
TRLitsey
One way to get to that window is this, in ACE 2014
Insert or edit tool for component.  At the Insert/Edit Component widow click on the Lookup button.  The Parts Catalog will open, this my take a few moments depending on your system and setup.  If the part you are woking with is already in the catalog it should be highlighted.  In the upper left corner of the widow there are four icons (on my setup anyway).  Hover the cursor over the icons to see a hint as to thier function.  Take a little care here.  The Add button will use the hightlighted record as a templete to add a new component to the Catalog.  The Edit button will allow you to change an existing record.
Good luck
Please mark this as a solution if it resolves you issue.
Thank you
