AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
251 Views, 2 Replies
Catalogs
I am trying to test Autocad electrical 2016 and at the same time try to draw a panel for a journeyman project.  Everything is done in Allen Bradley but I do not have a AB catalog.  I download one but when I try to unzip, it ask me for a password.  How can I truly test the software if I cannot even add a catalog to it to see just how easy or hard it is???  Anybody able to help?????
Mark
2 REPLIES 2
TRLitsey
It sounds like the mfg. has not been installed.  Take a look at the attached Word file.  It may help.  I hope the imbeded images come through.
Good luck.
Please note this as a solution if it resolves your issue.
Thank you
Please mark as a solution if this works for you, kudos are always welcome
TRLitsey
By the way, are you selecting the mfg.?  When the Parts Catalog opens it will have a default mfg. presented but you can select other available mfg.  See attachement.
Thank you
