- Mute
- Permalink
- Report
I have uninstalled and reinstalled ACADE 2019, uninstalled and re-applied the latest update (2019.1.4), and have done all with restarts after each installation. This has not fixed the "unhandled exception" error that pops up on launch or when attempted to add the ACEPUBLISH.ARX through the APPLOAD command dialog.
ACEPUBLISH.ARX is responsible for AEPUBLISH command, which does plotting for multi-page PDF documents from an Autocad Electrical project. This is a core ACADE feature that just... broke.
This is running on a perpetual license and I am not permitted to upgrade to a newer subscription plan or newer year (2020+) version of ACAD.
Also, the Support Article only addresses this problem as early as ACADE 2020 and the above attempts are exactly what is recommended to resolve this:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Unhandled-Exceptio...
Any suggestions?
