AutoCAD Architecture Customization
Welcome to Autodesk’s AutoCAD Architecture Customization Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture Customization topics.
C# Get object member from a dynamic block
2 REPLIES 2
cobygiffordBLCGD
172 Views, 2 Replies
I have a custom dynamic block.  Using c# I am able to iterate all instances of the dynamic block, get property and attributes values, etc.  As part of the dynamic block there are labels and line objects.  I need to get the bounds of the block.  However, when I do so the extents of the block are including all the of other members, thereby making the block larger than what I am trying to achieve.  What I really need is to get the bound of a specific member of the dynamic block which is a polyline.  I cannot figure out how to navigate the block programmatically to get to that object.  Any help would be great appreciated.  Thank you in advance.  I have also attached the .dwg file here.
Tags (2)
2 REPLIES 2
Gepaha
in reply to: cobygiffordBLCGD
@Gepaha you are awesome! That's exactly what I needed (br.Explode(entitySet);) and could not figure out how to extract the correct objects.  Thank you very much, greatly appreciated!
Forma Design Contest
AutoCAD Beta
