workspace not showing anything
when i open autocad it opens with a black screen and it is not showing anything at all.neither croshair nor any objects.exact same thing iis happening in paperspace also..and not the cursor is showing in the workspace.
pendean
Community Legend
Community Legend
Might be time to reset AutoCADARCH if you cannot select another workspace then back to your with WORKSPACE command https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
Victoria.Studley
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the suggestion that @pendean provided help you restore your workspace?
If so, please click Accept Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
