Centroid visibility command
EnricoD
EnricoD
Hallo,
is existing a command/option to make visible the centroid point of an irregular section in 2D with only one step ?
Thank you in advance.
in the attached example centroids are manually finded.
pendean
Community Legend
Community Legend
You can add your own symbol/line/block/point object using the Geomteric Center object snap I believe.
EnricoD
Yes, currently is the only solution I was able to find.
I was wondering if somewhere would be existing a command to show it with only one step and without changing the nature of the object.
Thank you very much
