door not visible
door not visible
salaimanimagudam
door not visible
salaimanimagudam
while I am using the door and selecting the wall and it's only visible as like opening not as a door
I meet this problem usually while I am changing the wall thickness from 4" to 9"
  even I meet the same problem for window
when restart the drawing its solved automatically
Er.M.P.SALAIMANIMAGUDAM .B.E., Aff.M.ASCE
Student Expert & Ambassador
pendean
Community Legend
Community Legend
Are all of your layers thawed and on?
salaimanimagudam
Yeah it's no problem in layers
Because when I use the door in 4.5" wall it's fully visible while I m using over a 9" wall then its look like a opening
This problem occurs only some time
If I restart the program its automatically problem get solved
pendean
Community Legend
Community Legend
"some time" and "restart... gets solved" may simply mean your video card is not capable: try getting updated drivers for it, ensure WIn10 is fully updated too, and if needed go into GRAPHICSCONFIG command and start turning off hardware settings.
Victoria.Studley
Hi @salaimanimagudam,
I'm just checking in to see if you need more help with this. Did the suggestion that @pendean provided work for you?
If so, please click Accept Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
