AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Unable to add basic dormer
1 REPLY 1
461 Views, 1 Reply
Hi All,
Happy New Year to you.
I'm using 2021 version of Autocad Architecture.
It's my first time at trying to add a basic dormer and for the life of me I cannot get it to work.
Help would be much appreciated. Basic DWG of what I am doing is attached. As far as I can tell the dormer structure is correct and cuts through the roof slab, but it just refuses to add as a dormer.
The error it gives is:
Walls are not connected.
Add dormer failed.
Make sure objects forming the dormer are closed and cut through full slab body.
Labels (2)
1 REPLY 1
Ok so in case it helps anyone else, this video gives the process nicely.
https://knowledge.autodesk.com/support/autocad-architecture/learn-explore/caas/video/youtube/lesson/...
I found, by using the default wall style that my actions worked and could create the dormer, the issue seems to be because I had the wall style set to ryker28WP7_0-1609858485621.png (because that's the wall style I'm using inside) and I presume it only works with 'external' walls styles or something like that anyway.
Hope this helps someone.
Forma Design Contest
AutoCAD Beta
