AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
stretching by grip isn't stretching the distance I put in
9 REPLIES 9
Message 1 of 10
NNewcomb
464 Views, 9 Replies
NNewcomb
Normally, when I grab a wall by the center grip and move it in a certain direction, type in a number like 4, it would slide that direction 4 inches. Suddenly this week, when I use this method, its moving it in the right direction but at randome distances. In this most recent case, I'm trying to go 4 inches and it's moving it 4'-7 3/16" when I type in 4 or 4". It is also, but not always, moving it at an angle towards my curser even though my ortho is on.
 I hope one of you can help! I don't know what I did to cause this.
9 REPLIES 9
Message 2 of 10
pendean
in reply to: NNewcomb
pendean
Community Legend
Community Legend
Turn off running osnaps and see if your issue goes away.
After you check a blank empty file to see if that problem is truly universal or just this one file, then ensure your DWG units are set to inches and not feet, and your PLAN command is set to Current UCS in case your UCS is rotated but your cursor is not.
Message 3 of 10
faugustom
faugustom
I misunderstood, ignore...
Message 4 of 10
NNewcomb
in reply to: faugustom
NNewcomb
I will look this up. I’m thinking it’s a setting I unknowingly or unintentionally changed by using one of the F keys or randomly clicking at the bottom since it’s across any drawings I open.
Message 5 of 10
NNewcomb
in reply to: pendean
NNewcomb
running osnaps?  All the other was verified before I posted. Thanks
Message 6 of 10
NNewcomb
NNewcomb
I really feel your reply might have helped but I can't try it since you deleted it. Maybe not though
Message 7 of 10
NNewcomb
NNewcomb
I haven't found the issue's answer yet. I have noticed it's not just stretching a wall. It's also moving items like blocks and doors/windows etc. I used to be able to grab the middle handle and move curser in direction(with ortho on) I wanted it to go, type in distance and hit enter. Now I have to use the move command or it just tries to go in the direction of my curser and the distance I type in doesn't matter
Message 8 of 10
NNewcomb
NNewcomb
All checked. None of these were the issue.
Message 9 of 10
pendean
pendean
Community Legend
Community Legend
so the problem is unique to this one file? No issue in other DWG files not related to this project?
IF DYNMODE is set to 0, does the issue go away?
DSETTINGS command, Dynamic Input tab, Pointer Input Settings button, your chosen FORMAT options in this file compared to a no-such-problems other file are how different?
Message 10 of 10
NNewcomb
NNewcomb
No. the problem is in any file I open. But DYNMODE was it. SMH
