Normally, when I grab a wall by the center grip and move it in a certain direction, type in a number like 4, it would slide that direction 4 inches. Suddenly this week, when I use this method, its moving it in the right direction but at randome distances. In this most recent case, I'm trying to go 4 inches and it's moving it 4'-7 3/16" when I type in 4 or 4". It is also, but not always, moving it at an angle towards my curser even though my ortho is on.
I hope one of you can help! I don't know what I did to cause this.
Solved by pendean. Go to Solution.
I haven't found the issue's answer yet. I have noticed it's not just stretching a wall. It's also moving items like blocks and doors/windows etc. I used to be able to grab the middle handle and move curser in direction(with ortho on) I wanted it to go, type in distance and hit enter. Now I have to use the move command or it just tries to go in the direction of my curser and the distance I type in doesn't matter
so the problem is unique to this one file? No issue in other DWG files not related to this project?
IF DYNMODE is set to 0, does the issue go away?
DSETTINGS command, Dynamic Input tab, Pointer Input Settings button, your chosen FORMAT options in this file compared to a no-such-problems other file are how different?
