Hello!
So I am working on a layout for my Senior Design class. I have finished the design and I am supposed to print/plot it on a 24x36 paper.
However, I don't know how to make the scale in proportion to that. I need the scale to be 1"=150' but I am do not know how to do that.
I will be grateful for any help. Thank you!
Solved by pendean. Go to Solution.
I can't imagine a teacher that would want you to use a non-standard scale vs using a larger standard sheet size. Your best option is to use 1/8"=1'-0" and to matchline and create multiple sheets per floor with key plan. You would definitely not want to show any potential employer you couldn't work with standard scales.
You don't "put it into layout": you click on the layout you want, start PAGESETUP command and ensure the paper size you want is selected along with the printer/plotter to want to use. Then you start MVIEW command, draw a rectangle about the size of the area you want it to take up on the page: now you have a viewport. Your model tab content will appear inside this viewport.
Did you get that far? If yes, then next thing to do is set the viewport to a scale. If 1=150 makes your model disappear you need to try a different scale until you see that fits.
NOTE: 1:150 is not equal to 1"=150.0'.
What really bothers me as an instructor though is why the fundamentals of paper space scaling are still a mystery to someone doing a "senior" project. In my AutoCAD class, we get that drilled into the process within the first month of the first class.
