repeat polar array beyond 360 degree
im facing the issue where i have to copy 137.5 degree from the previous line(radius of circle) center of circle as pivot
not able to do it with action recorder aswell as it records coordinates of the previous line - so second line overlaps on what i manually did - i have no idea about lsp aswell but it could be helped with
dbroad
You are posting in the ACA newsgroup. The action recorder is not an ACA feature and also isn't intended to support LISP.  You may need to describe your need further, especially why you want a polar array to spin more than 360 degrees from the start angle.
Architect, Registered NC, VA, SC, & GA.
